Can an ISO timestamp be part of the exported device data? Not just the Unix timestamp.
(either from devices or notebook import dataexport)
No, we are locked into the Unix timestamp when exporting device data.
You could use Notebooks and add a new column to your data export with an ISO date, using the supported Pendulum library:
Or you would have to do the conversion directly on your local machine.
@Aidan_Zebertavage
Apologies, in digging into this further, ISO date is on the export when you use the Request Data Export bulk action.
And I just pulled an export from a sample application I have running, see below:
Are you looking for other sources for this timestamp? Can you help me understand what you mean by “from devices” in your initial post?
@Aidan_Zebertavage
ok, great.
I had missed it was part of Bulk device export
But that option won’t allow me do select just the attributes needed.
That’s correct, the bulk device export contains all the associated device data/attributes.
I would look at using Notebooks to better customize the device data being exported.
@Aidan_Zebertavage
