Device:Export Node wrong HOUR timestamp
:sos:Currently I have a dashboard Report Input Control Box that triggers a dashboard Device:Export Losant API process with 3 options for ‘back in time’ reporting (in ms) : 24 hrs, 7 days and 30 days :arrow_heading_down:
The report is sent to an e-mail, looks great - but the actual HOUR in the ISO Date is ‘off’ by 5 hours (I’m assuming is a Time Zone issue as I’m in GMT-5) :arrow_heading_down:
I tried various things, looked for solutions on the Forums, including adding a 5hr difference/Time Zone option in the dashboard box :arrow_heading_down:
But I just end up actually offsetting not just the HOUR but ALL data by 5 HOURS since the problem here is just the HOUR ‘stamp’, not the whole data. I can ‘fix’ this in the final :page_facing_up:CSV/XLS VBA report, but was wondering if I’m missing something or if there’s a way to do it right out of the platform which would be best. All :ballot_box:suggestions are welcomed. Thanks, :red_circle:
Hi @Jose_Cruz,
I might recommend trying out the {{formatDate }} helper or the Date/Time Node. I frequently use these with a template of YYYY-MM-DDThh:mm:ss[Z], as it forms my timestamp without the UTC offset. This should remove the 5-hour date change you are seeing while still displaying the time correctly.
Please let me know if this does not work with your use case!
Ok, let me try that and I’ll get back to you - as always, thank you and :christmas_tree:Merry Xmas to all at :infinity:Losant. :red_circle:
