Set device connection status via API?
Hi there,
would there be a way to force set the device connectivity status?
I have a set of devices that are connected to another system and I can check via their API whether is online or offline.
Ideally I don’t want to create a separate attribute for that, because it would be nice to see the device Connection Status in the dashboard panel.
Yes:
Note, it will only work on device classes that can connect to our MQTT broker (so, not systems or peripherals).
That worked just fine!
