Hi there,
I created a few simulated devices and also created a workflow to generate random numbers for this devices.
I want to show the Device Connection Log on a dashboard but gets a message “No Log entries found”
Although this is not real devices is there a way to populate the connection log?
Thank You
There is an API endpoint you can use to manually set a device’s connection status. The easiest way to leverage this is to use the Losant API Node in a workflow and choose the ‘Device: Set Connection Status’ Resource/Action. Then, set either {"status": "connected"} or {"status": "disconnected"} in the request body.
Thank You, it is working now
