Problems in the Edit Indicator Block when using Markdown.
When using the “##” markdown the text of the block increases instead of decreasing the size and the text color is also the same as the background color defined in the block.
It looks like there might be a CSS style that is not allowing the larger word to be split mid-word. I would try going into the CSS styling for the experience page and try to adjust the styling to make it work for you.
A note: We try to support these CSS style workarounds as best we can as we update the platform, but I cannot guarantee that the workaround will work in the future.
