Notebook input file only
I need to send 24 hours of data from 10 devices, every midnight to AWS.
I have started setting up a notebook, but all I really need to send is the file as defined Input file for the notebook.
Can I have an “empty” notebook without a output file? Would that even execute?
@Lars_Andersson,
Yes. You can create a notebook that moves a file from the input directory to the output directory (in Python).
After the Notebook is done, you can trigger a workflow to then forward along your data to AWS.
One thing to keep in mind, when you get the outputs of a Notebook in a Workflow. You don’t get the raw data, you get a download link to the raw data. See more in the docs:
