Is there a way to regularly schedule automatic csv exports of (multiple) device data? thx
We have a few options for you to explore for device data exports. Take a look a the below forum threads for how we’ve approached this in the past.
Our best recommendation since you’re looking to export multiple devices would be to configure Notebooks and use the Request Input Data export resource. Losant has compiled some good examples of Notebooks here.
We built up a test notebook configuration and sample workflow to execute a scheduled data export. See below. If you modify the trigger in the workflow to be a Timer - you can set up the frequency at which you want to run the export.
Let me know if this doesn’t work for your use case.
@Aidan_Zebertavage
