Hi there
I’m receiving the correct string for location:
but in data explorer doesn’t show up:
Any idea?
The attribute has the correct config
This is likely due to the aggregation you have selected in the Data Explorer. It defaults to MEAN, and since there’s no concept of averaging GPS coordinates, the field is left blank.
You can try changing the aggregation to FIRST or LAST. You can also change it to NONE, which will not perform any aggregations on the data and will return the raw reported values.
