Filtering Difference Between Device List Block and Location Block
Logged in user gets the correct machines listed in the Device List Block which can be seen below:
Settings for Device List Block:
Logged in user sees devices that don’t belong to him listed on the Location Block.
Settings for Location Block:
*** Note the logged in user pictured above is of the experience group “machinesaver”
Machine_A Settings:
Machine_B Settings:
Machine_C Settings:
I’m wondering, does the Location Block filters the same way that the Device List Block does?
Hi Leo,
The GPS Location block is built with an “or” operator for Device IDs/Tags, so with this statement below you will be getting back locations that match either of the tags.
I’m going to look around and see if I can find a way around this somehow, but I am not sure how likely that is. However, if you were to only filter by {{ctx.group}} or device=machine, you would see some filtering occur.
