I am new to Losant and Huzzah Feather. I am trying out the Workshops but got stuck while trying to compile the project. I am getting the following error:
fork/exec /Users/jamesmcfarlane/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++: no such file or directory Error compiling for board Generic ESP8266 Module.
Thanks for the prompt response that got it working. But in the serial monitor a I am getting the wrong temperature readings. I have the TMP36 connected to left pin to +, center pin to the Huzzah Feather ADC and the right pin to - . Would this have anything to do that the max voltage for the ADC pin is 1 volt?
Connecting to Losant…Connected!
This device is now ready for use!
Button Pressed!
We moved away from the Feather Huzzah several months ago, so most of the instructions currently in our documentation are referring to the NodeMCU dev kit. The Feather requires different wiring and different firmware. You can get access to the original instructions here: https://docs.losant.com/getting-started/losant-iot-dev-kits/builder-kit-feather
The Feather-based kit comes with additional resistors that act as a voltage divider. Check out the link above for the instructions on how to wire it up.
