ESP8266 - Not connecting to the Losant Platform
Hello, I’ve been trying to to the WORKSHOP 1 – INTERNET BUTTON. The device is able to connect to the internet but when it tries to connect the Losant platform (“Connecting to Losant…”), it just hangs.
This is the code I’ve used:
 * Workshop example for a simple internet button using the Losant IoT
 * platform.
 * Visit https://www.losant.com/kit for full instructions.
 * https://www.losant.com
#include <ESP8266WiFi.h>
#include <Losant.h>
// WiFi credentials.
const char* WIFI_SSID = "XXX";
const char* WIFI_PASS = "XXX";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "XXX";
const char* LOSANT_ACCESS_KEY = "XXX";
const char* LOSANT_ACCESS_SECRET = "XXX";
const int BUTTON_PIN = 5;
WiFiClient wifiClient;
void connect() {
  // Connect to Wifi.
  Serial.println();
  Serial.println();
  Serial.println(WIFI_SSID);
  WiFi.persistent(false);
  WiFi.mode(WIFI_OFF);
  WiFi.mode(WIFI_STA);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Connect to Losant.
  Serial.println();
  device.connect(wifiClient, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET);
  while(!device.connected()) {
    delay(500);
    Serial.print(".");
  Serial.println("Connected!");
  Serial.println();
void setup() {
  Serial.begin(115200);
  // Giving it a little time because the serial monitor doesn't
  // immediately attach. Want the workshop that's running to
  // appear on each upload.
  delay(2000);
  Serial.println();
  Serial.println("Running Workshop 1 Firmware.");
  pinMode(BUTTON_PIN, INPUT);
  connect();
void buttonPressed() {
  Serial.println("Button Pressed!");
  // Losant uses a JSON protocol. Construct the simple state object.
  // { "button" : true }
  root["button"] = true;
  // Send the state to Losant.
  device.sendState(root);
int buttonState = 0;
void loop() {
  bool toReconnect = false;
    toReconnect = true;
  if(!device.connected()) {
    toReconnect = true;
  if(toReconnect) {
    connect();
  device.loop();
  int currentRead = digitalRead(BUTTON_PIN);
  if(currentRead != buttonState) {
    buttonState = currentRead;
    if(buttonState) {
      buttonPressed();
  delay(100);
Hi @Nick_C,
Since the latest release of that library, we’ve updated the example for the ESP8266:
I would recommend basing your code off of that example as it is updated to the latest and greatest.
Appreciate it. As simple as that.
