I have constant problem with that program im total newbie,
hardware nodeMCU 1.0 firmware v3
password ssid etc changed for safety.
I would be very happy to get any
advice.
Code:
#include <DHT.h>
#include <ESP8266WiFi.h>
#include <Losant.h>
#define DHTPIN 6 // what digital pin the DHT22 is conected to
#define DHTTYPE DHT22 // There are multiple kinds of DHT sensors
DHT dht(DHTPIN, DHTTYPE);
// WiFi credentials.
const char* WIFI_SSID = "123";
const char* WIFI_PASS = "123";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "123";
const char* LOSANT_ACCESS_KEY = "123";
const char* LOSANT_ACCESS_SECRET = "123";
WiFiClientSecure wifiClient;
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
Serial.println(WIFI_SSID);
WiFi.persistent(false);
WiFi.mode(WIFI_OFF);
WiFi.mode(WIFI_STA);
unsigned long wifiConnectStart = millis();
// Check to see if
Serial.println();
Serial.print("SSID: ");
Serial.print("Password: ");
Serial.println(WIFI_PASS);
Serial.println();
delay(500);
Serial.println("...");
// Only try for 5 seconds.
if(millis() - wifiConnectStart > 5000) {
Serial.println("Failed to connect to WiFi");
Serial.println("Please attempt to send updated configuration parameters.");
return;
Serial.println();
Serial.println();
HTTPClient http;
* "deviceId": "575ecf887ae143cd83dc4aa2",
* "key": "this_would_be_the_key",
* "secret": "this_would_be_the_secret"
String buffer;
root.printTo(buffer);
if(httpCode > 0) {
if(httpCode == HTTP_CODE_OK) {
} else {
if(httpCode == 400) {
} else if(httpCode == 401) {
} else {
} else {
http.end();
// Connect to Losant.
Serial.println();
while(!device.connected()) {
delay(500);
Serial.print(".");
Serial.println("Connected!");
Serial.println();
void setup() {
Serial.begin(115200);
Serial.setTimeout(2000);
while(!Serial) { }
Serial.println("Running DHT!");
connect();
root["humidity"] = humidity;
root["tempC"] = tempC;
root["tempF"] = tempF;
device.sendState(root);
Serial.println("Reported!");
int timeSinceLastRead = 0;
void loop() {
bool toReconnect = false;
delay(1000);
toReconnect = true;
if (!device.connected()) {
toReconnect = true;
if (toReconnect) {
connect();
device.loop();
// Report every 2 seconds.
if(timeSinceLastRead > 2000) {
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print(t);
Serial.print(" *C ");
Serial.print(f);
Serial.print(" *F\t");
Serial.print("Heat index: ");
Serial.print(hic);
Serial.print(hif);
Serial.println(" *F");
report(h, t, f, hic, hif);
delay(100);
timeSinceLastRead += 100;
