Delete Data but also Connection status
Hi there,
would be helpful to enable the user to also reset the connection status when it clicks on delete all data.
Because in most cases the connection status relies on the last time there was a data push, so it would be inconsistent if I have deleted all the dat but it still shows connected since a few hours ago.
I see what you mean; thanks for the info. I’ll point that out to the engineering team.
One workaround you can employ for now: If you change the device’s class to one that does not connect to the broker - for example, “peripheral” or “floating” - and then change it back to its original device class, that will clear the connection status from the device.
