Pretty minor bug, but caused a bit of confusion until I was able to track down what was happening:
When I clone a map block with no resolution set (I created it through the API and didn’t define a resolution at all), the new map block has a resolution of 60000 when I query it through the API, but when I edit the block through the web UI it says that the resolution is “None”.
Steps to reproduce:
- POST /dashboards with the following template (IDs have been removed):
"name": "Location Bug",
"orgId": "ORG_ID",
"refreshRate": 60,
"defaultTheme": "light",
"public": false,
"blocks": [
"blockType": "map",
"id": "LVwOZSoydz",
"width": 2,
"height": 2,
"config": {
"duration": 86400000,
"deviceIds": [
"{{ctx.currentDevice}}"
"deviceTags": [],
"pinMode": "simple",
"resizedPins": true,
"startColor": "#ff261b",
"endColor": "#8db319",
"defaultZoom": "auto",
"includeLines": true,
"includeArrows": false,
"defaultPitch": 0,
"defaultBearing": 0,
"iconTemplate": "{{#if isLastPoint}}\n{{colorMarker '#8db319'}}\n{{else if isFirstPoint}}\n{{colorMarker '#ff261b'}}\n{{/if}}",
"popupTemplate": "##### **{{deviceName}}** {{#if isLastPoint}} (Current Location){{else if isFirstPoint}} (Starting Location){{/if}}\n\n{{format time}}\n\nLatLng({{format latitude}}, {{format longitude}})",
"compositeResult": true,
"attribute": "location"
"startX": 0,
"startY": 0,
"applicationId": "APPLICATION_ID",
"title": "Map 1"
"contextConfiguration": [
"validationEnabled": false,
"name": "currentDevice",
"type": "deviceId",
"defaultValue": "DEFAULT_DEVICE_ID",
"validationConfig": {}
Go to the dashboard and clone the “Map 1” block
GET /dashboards/{dashboardId}. This is what I get for the blocks:
"blockType": "map",
"id": "LVwOZSoydz",
"width": 2,
"height": 2,
"config": {
"deviceIds": [
"deviceTags": [],
"defaultPitch": 0,
"startX": 0,
"startY": 0,
"title": "Map 1"
"blockType": "map",
"id": "H0V56H8Scq",
"width": 2,
"height": 2,
"config": {
"deviceIds": [
"deviceTags": [],
"defaultPitch": 0,
"attribute": "location",
"resolution": 60000
"startX": 2,
"startY": 0,
"title": "Map 2",
Compare this to the web UI, where Map 1 has the exact locations with the Resolution listed as “None”:
whereas the cloned Map 2 has locations grouped per minute even though the Resolution is listed as “None”:
