I have a device that runs node 10 which defaults to TLS 1.0, and I was getting either ECONNRESET or a handshake error when I made a /devices GET request from the device. I tried a couple of things to fix this like setting the minimum TLS version node argument to 1.2 and a different firmware version with node 14 (which defaults to TLSv1.2), but I wasn’t able to get the API request to complete.
What’s weird is in the last few days the device came online, so it must have been able to complete that request - the device connection depends on the device querying for itself or adding itself with the API. I saw the post about dropping support for TLS 1.0 and 1.1 and was wondering if anything has changed yet on the server side, or if I was having some other issue. Thanks!
Device Errors:
[ 37.395] [1611:1839:0905/111338.525313:ERROR:ssl_client_socket_impl.cc(1050)] handshake failed; returned -1, SSL error code 1, net_error -101
"stack":"Error: read ECONNRESET
at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)",
"message": "read ECONNRESET",
"code": "ECONNRESET",
"config": {}
