I’m tring to see my data but it seams to have a lit bug on the chart because the line draw a “Z” and we got for certain time value multiple temperature and humidity mean value, witch is strange.
Interesting as that chart appears, it was the result of a bug on our end. We are now double-checking that data is sorted by time in the dashboard block (it was being returned out of order in the API response, which we will also fix). If you use the dashboard time jumper to go back in time to when you saw this data pattern, it should be corrected now.
Thanks for the heads-up!
Thanks for your response, next time i’ll see that, if I see it again, I’ll give it a try.
