RaspberryPI B+ - SeedStudio Digital Temp&Humidity sensor
Can someone give me an example of how to setup the Losant MQTT to pull data from a temp&humidity digital sensor attached on a raspberrypi and how the wiring has to be done on the workflow to visualize.
I have all the node.js setup with losant-mqtt installed in the PI (model B+ JESSIE)
Hi!
Could you post a link to the sensor you have? Is it the DHT22 temperature and humidity sensor?
I’ll be testing this out today. But this looks promising:
