Good evening, I have a question) so i have my microcontroller ESP8266 and i connected my DHT22. I need to connect my microcontroller with DHT to my account in Losant but i have this issue, i do not know what happen. Do y
It looks like your device is either continuously trying to connect to the platform (as in your connect() function in your code is in you loop()) or you have two devices connecting to Losant with the same Device ID.
Also, just a quick note, when your device is connected to Losant, you will be unable to use the Device Simulator (as the warning states).
Would you be able to share the code you are using on your ESP8266 device? Can you confirm that you are using a unique Device ID for this device?
Here is mu code, i delete my previous ESP8266 device with button function, then i create a new application with DHT22 and i described what happened.
I need that in device log display humidity, tempC, tempF, heatindexC and heatindexF
Here is my code.
Thank you so much for your help!
//#include "DHT.h"
#include "DHTesp.h"
#include <ESP8266WiFi.h>
#include <Losant.h>
#define DHTPIN 14 // what digital pin the DHT22 is conected to D3
#define DHTTYPE DHT22 // There are multiple kinds of DHT sensors
//DHT dht(DHTPIN, DHTTYPE);
DHTesp dht;
// WiFi credentials.
const char* WIFI_SSID = "**********";
const char* WIFI_PASS = "**********";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "60f0d4436de8120006775e14";
const char* LOSANT_ACCESS_KEY = "ef2c2384-7938-4661-a06c-3b0148dc2384";
const char* LOSANT_ACCESS_SECRET = "0a9cc6a34967e0c6da2a66b64a1deee677bd3a59ce462c0ed1211e496c16951f";
//WiFiClientSecure wifiClient;
WiFiClient wifiClient; // << works
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
Serial.println(WIFI_SSID);
WiFi.persistent(false);
WiFi.mode(WIFI_OFF);
WiFi.mode(WIFI_STA);
unsigned long wifiConnectStart = millis();
// Check to see if
Serial.println();
Serial.print("SSID: ");
Serial.print("Password: ");
Serial.println(WIFI_PASS);
Serial.println();
delay(500);
Serial.println("...");
// Only try for 5 seconds.
if(millis() - wifiConnectStart > 5000) {
Serial.println("Failed to connect to WiFi");
Serial.println("Please attempt to send updated configuration parameters.");
return;
Serial.println();
Serial.println();
HTTPClient http;
* "deviceId": "575ecf887ae143cd83dc4aa2",
* "key": "this_would_be_the_key",
* "secret": "this_would_be_the_secret"
String buffer;
root.printTo(buffer);
if(httpCode > 0) {
if(httpCode == HTTP_CODE_OK) {
} else {
if(httpCode == 400) {
} else if(httpCode == 401) {
} else {
} else {
http.end();
// Connect to Losant.
Serial.println();
//device.connectSecure(wifiClient, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET);
device.connect(wifiClient, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET); // << works
while(!device.connected()) {
delay(500);
Serial.println(device.mqttClient.state()); // HERE
Serial.print(".");
Serial.println("Connected!");
Serial.println();
void setup() {
Serial.begin(115200);
Serial.setTimeout(2000);
while(!Serial) { }
Serial.println("Running DHT!");
dht.setup(14, DHTesp::DHT22); // Connect DHT sensor to GPIO 14//17
connect();
root["humidity"] = humidity;
root["tempC"] = tempC;
root["tempF"] = tempF;
device.sendState(root);
Serial.println("Reported!");
int timeSinceLastRead = 0;
void loop() {
bool toReconnect = false;
toReconnect = true;
if (!device.connected()) {
toReconnect = true;
if (toReconnect) {
connect();
device.loop();
// Report every 2 seconds.
if(timeSinceLastRead > 5000) {
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.getHumidity();
float t = dht.getTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.toFahrenheit(t);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h, true);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print(t);
Serial.print(" *C ");
Serial.print(f);
Serial.print(" *F\t");
Serial.print("Heat index: ");
Serial.print(hic);
Serial.print(hif);
Serial.println(" *F");
report(h, t, f, hic, hif);
delay(100);
timeSinceLastRead += 100;
I’m taking a close look now. While I do that, can you confirm that you are using a unique Device ID for this device? As I mentioned, this type of issue is sometimes indicative of 2 devices connecting to Losant with the same Device ID.
