Trying to use twilio voice to make an outbound call based on an event.
The sms version works fine, but when trying to configure Webhook out it says
no : “To” defined
Tried several different ways
To= 18005557655
To: “18005557655”
And several other ways
None seem to work
Hi @Jordan_Reyes,
Could you include a screenshot of your Webhook configuration? I’m going to test this out and try to replicate the issue.
@JuliaKempf Using a virtual button to make http request
Post
And that’s where the “To” issue arises
Hi @Jordan_Reyes,
It looks as though the root cause is the required Twilio format of the POST. I would recommend using Postman or another similar service to try executing as a cURL command. If you are able to successfully POST using a cURL command, we will be able to form the command to fit the HTTP Node.
Yes there was no issue when using postman,
worked the first time
@Jordan_Reyes,
Can you include a screenshot of your POSTMAN configuration?
