When will Lora support be implemented?
Below are a couple of options we’ve seen successfully used in production for LoRa:
- If you’d like to use The Things Network, using their HTTP Integration is a very easy way to get data into our platform.
- You can use something like the Laird LoRa Gateway with their packet forwarder to push UDP messages directly into an Edge Workflow using the UDP Trigger.
There are a lot of components that make up a complete LoRa stack. Can you explain a little more on how you’d like Losant to support LoRa?
