Helium integration
Hi, do you plan to support Helium network integration on Losant or on the Helium Console ?
Hey @SEAN_O_CONNELL,
There currently is not a direct integration with Helium and Losant, but you can use Helium’s MQTT Integration to send data to Losant’s MQTT Broker.
You could also use Helium’s HTTP Integration with a Losant Webhook.
Let me know if either of these options work or if you were looking for something different.
When using an HTTP Integration, Helium and The Things Network will work very similarly. Check out The Things Network Application Template to see how this is implemented.
