I am successfully sending MQTT messages with my device to Azure IoT hub and I want to visualize the data in Losant. I have created the workflow that fetches the MQTT integration I created for Azure.
I have followed this tutorial but I am unable to receive any MQTT messages. Losant seems to not be able to connect to Azure’s “broker”.
Were you able to generate the SAS token with the iothub-explorer npm package? From the screenshot you included, it looks like your trying to make a connection with the SharedAccessSignature rather than a generated token.
It will take me some time to run through this process and verify that things have not changed with Azure since the publication of the blog post you referenced.
Once I do, I will be sure to update you with anything I find.
In the meantime, the only other recommendation I can make is to verify that the security policy that you copied the connection string - primary key for has the correct permissions.
