Dynamic virtual device IDs in Workflows
Hi again,
Right now I’m setting up workflows, and I would like to be able to create a derived attribute on a device, i.e. one that the device does not report directly, but that I can compute from what it reports. It looks like I should use a virtual device for attributes that I set in workflows.
Since I have more than one hardware device, I’d like for each of them to have a corresponding virtual device. However, from what I can tell in the workflow editor, the “Virtual Device” node needs a constant device ID known ahead of time. Is there a way I can use the device ID from the workflow trigger to select a virtual device to update? Essentially, I’d like to use a template to find the virtual device corresponding to the real one. I could associate them perhaps by storing the virtual device’s ID as an attribute on the real device.
Great feature request! We did implement this functionality on the Device Command node and will roll it out as soon as possible to the Virtual Device node as well.
Our release today does provide support for specifying the virtual device ID from the payload when setting virtual device state. Thanks for being patient!
