Default name of pages becoming folders in Windows
Hey :smiley:
I’m using the CLI to upload and edit my experience and I’ve found a problem.
Here’s how the pages archives were nominated:
MicrosoftTeams-image (1)
And this is how the archives been showed on my desktop (I’m using VS Code), they turned into folders.
MicrosoftTeams-image (2)
The problem became when I was trying to upload my changes and the archives were been deleted because they’ve couldn’t be found by the fact there had turn into folders.
Idk if it’s just a windows problem.
@Thiago_zils,
Thanks for bringing this to our attention. I’m working to reproduce the issue on my end to better understand next steps. I’ll follow up today with more information.
@Aidan_Zebertavage
Hi @Thiago_zils,
We’ve been digging into this on our side and the issue looks to be a result of using a past version of the CLI.
Can you make sure you have the Losant CLI updated to the latest version - 1.2.2.
You can check the version of the CLI you’re running with: losant --version.
If you need to upgrade to the latest version of the CLI, you can run:
npm i -g losant-cli
Once you have the latest version, run:
losant experience download
This command will migrate the files associated with your experience and sanitize them properly, creating the individual files you need rather than directories.
@Aidan_Zebertavage
Hey @Aidan_Zebertavage ,
I am facing the same problem but in the Files.
I checked and I am already with version 1.2.2.
Should I open a new issue, or can I just leave it here in this comment?
Thanks in advance!
Best regards from Brazil.
Hello @matheusquost,
I can add you +1 to the issue in our system, and will be sure to follow up with you once I learn more about it!
