Using the CLI, uploading a file from local folder “./gateways/dra/images/” leads to creation of a new root folder named by the entire Windows folder path:
Thanks for the report. We see the issue and are working on a fix. I will follow up once it is resolved.
We just published an updated version of the Losant CLI that addresses the Windows path issue. If you upgrade your local copy of it, any files in a child directory should correctly be nested on the Losant side matching what you have on your computer.
Thanks for bringing this to our attention.
Internal
Hi Dylan,
it works fine.
Many thanks and Best Regards,
