Would be nice to purge data from a data table without having to recreate it.
Looks like the only way is through a workflow now.
it would also be nice to import a table definition
You’re correct. The API does have a “truncate” call, which is exposed in the workflow. There’s already a ticket to add a button to the UI. I’ll bump that ticket.
Hey @Lars_Andersson,
I wanted to let you know that there is now a feature that allows you to purge data from a Data Table.
You can do so by clicking the menu button on the right side of the Data Table:
And then selecting Delete Rows:
You’ll be greeted with this modal:
Where you will be able to visualize the Query and acknowledge that this action will be permanent. You can read more about Deleting Data Table Rows in our docs!
