I am getting zero errors in Flow:Get Log Entries., although i have errors. Is this because of the timeframe I am looking into? Thanks in advance.
Captured thru Flow:Errors
We’re actually deprecating that old endpoint in our upcoming (October) release. To retrieve aggregated workflow statistics and errors, you should use the Flow: Stats and Flow: Errors API calls instead - or, alternatively, the Flow Version: Stats and Flow Version: Errors endpoints.
Rather than two separate end points, is there an end point that provides both? when a workflow runs and generate errors, what is the walltime and without errors same flow what is the walltime? Just a hypothetical scenario.
No, sorry, we do not maintain separate timing stats for flow runs that encounter an error vs. those that do not.
Bear in mind also that a workflow execution can branch into multiple parallel paths; one of those paths could encounter an error while the other does not.
Understood. Thanks for the help!!
