Since the newly created webhooks were listed on the second page, I was unable to select them from the Webhook Trigger node. Is there a known workaround for this issue?
Looks like we’re only showing 50 webhooks in the trigger’s selector. I’ll file a ticket to get that fixed. That said, 50 webhooks is way more than we see most users have in their applications. Can I ask what your setup is that requires so many? I may be able to suggest a way of simplifying things.
Yes; visit the webhook’s detail page and click the “Workflows” tab. From there, you can create a new workflow with this webhook selected in the trigger. More info can be found here: https://docs.losant.com/applications/webhooks/#associated-workflows
Just following up - we did get this bug fixed in our latest platform update. You should now be able to select any of the webhooks in your application using the dropdown in the Webhook Trigger. Thanks for bringing this to our attention.
