Hi Losant Support,
I’m hoping to understand whether or not is possible to access the value of a device tag for the purposes of using the tag to control the formatting of a time-series.
My specific example relates to the transformation of a distance to a percentage fill without use of a supplementary workflow to create a new attribute through the time-series expression feature:
I’m struggling to access the device tag values associated with the min and max fill points for a container which are stored are associated with the device. In this example, the device is being accessed as a context variable ({{ctx.deviceId-0}})
Is it possible to access tag values for the expression? If so could I please be provided a basic handlebar snippet to assist with using this feature?
Thank you!
Ben
PiP IoT
