Query by condition with Data Series Node
Hello Losant Team
is it possible with a data Series Node get all registers by a condition “greater than”?
For example in SQL i would do something like this:
SELECT *
FROM SpecificDevices D
WHERE customValue > D.value
CustomValue is a value that i set
D.Value is a specific value from a specific device
Thanks :slight_smile:
Hi @Jonathan_Calderon!
You can query devices by device tag values (link), but only by equal (===) or not equal (!===). No other logical operators are currently supported for device queries.
We’re currently evaluating ways to support this functionality on our platform.
Hi Sebastian
Don’t worry about the devices. I have a list of devices and I will get data from them using a loop. My question goes to the WHERE.
Let me clarify. I have two attributes and i want to use one to do a condition like attribute1 < {{value}} and if true i get attribute 2.
I think that in Mongo DB is like this
 $and:[
   "id": {"$eq": {{idDevice}} },
   "nameAttribute1": { "$gt": {{value}} }
Just to clarify - what dashboard block are you referring to?
Sebastian I’m so sorry! i was talking about this
I got confused and i want to say NODE. Sorry hahahahaha
Now i edit all the errors, sorry!
There is not a way to do it as a direct query, but with some extra work you should be able to get to the result set you are looking for.
Instead of using the Data: Time Series Node (which will only allow you to query one attribute at a time), use the Losant API Node and the Data: Time Series Query action. This will allow you to return multiple attributes in one request.
You can then use a Function Node (or a Loop Node and a series of other nodes) to filter those points down to only the ones that match the condition you are describing - or to mutate those results to return different values based on your condition.
Hi @Dylan_Schuster
I will try your solution!
Thank you very much @Dylan_Schuster and @Sebastian_Turner
