Hello! hopefully, this is not a duplicated one, I looked up and couldn’t find anything related to this.
I need to create a time series chart that displays historical temperatures for a list of devices, all in the same graph. The list of devices is dynamic, so I’m grouping them using a custom tag.
The Time Series Graph won’t work since, if I add a segment that points to the list of devices(by using the tag) it will aggregate the data. And using one segment by device is not possible for two reasons: 1) The list of devices could change 2) Imagine a scenario with 50 devices or more.
So now, I’m trying to integrate a third-party JS based chart (ZingChart) in Losant dashboard. For that, I was looking to use the “Custom HTML” block, but apparently there is no way to create a query that gathers the temperature from a list of devices (filtering by tag) without aggregating the data.
Another option would be to create a workflow where I could create my own time serie. The Data: Time Serie Node allows you to create a time serie payload for a list of devices with None aggregation.
But how can I point this time serie from the Custom HTML block?
I was thinking of creating a “virtual” device that would contain the timeserie data from the entire list of “real” devices, and then create a query in the Custom HTML that uses this single virtual device as input. But that’s kind of hacky and I was hoping to find a better way of doing this.
Any ideas or good practices regarding this?
Thank you very much in advance!!
