I am a huge fan of the Pushbullet service, and think an Output
of Pushbullet would be sweet.
Their API is super simple. You can push a note by sending a POST
to https://api.pushbullet.com/v2/pushes
with a message body similar to:
{"type":"note", "title":"Push Title", "body":"This is a push message"}
The only thing required to send yourself a note is the body formatted as such, and an Access-Token
header that you can get from your account settings page. Being able to select a push type (note, link, etc.) and then adding your access token in the configuration would be sufficient I believe to get started.
Robbie
