I have a PLC where some data are stored in arrays. (2 arrays with 36000 datapoints in each)
Should I be able to read an entire array from the edge agent using a OPC Read?
We have not tested an array of that size internally using the OPC-UA Read Node, however, we have not placed any limitations on the size of arrays that can be read, and see no reason why it wouldn’t work.
I would recommend proceeding with configuring the node to read your array as required and give it a shot. Let us know if you run into any issues.
@Aidan_Zebertavage
