Losant edge agent raspberry pi install fail
when i run this
# AMD
sudo add-apt-repository \
   "deb [arch=amd64] https://download.docker.com/linux/ubuntu \
   $(lsb_release -cs) \
   stable"
i get this
Traceback (most recent call last):
  File "/usr/bin/add-apt-repository", line 95, in <module>
    sp = SoftwareProperties(options=options)
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
    self.reload_sourceslist()
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
    self.distro.get_sources(self.sourceslist)
  File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
    (self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/buster
Hi @steven_ri,
Thanks for posting. This looks like an issue installing Docker on the Pi. Not particularly an issue with the Losant Edge Agent. There have been some known issues installing Docker on the “Buster” distro of Raspbian.
See: https://github.com/docker/for-linux/issues/709
There are some workarounds in there that may help! Otherwise, I’d recommend using an older version of Raspbian until the issues are fixed.
thank you i will try that
