Hi there.
I am reporting an issue with Arduino IDE, when trying to compile an example code for ESP8266.
My IDE version is 1.8.9 (Windows Store 1.9.21.0) with Losant library 1.3.0, Arduino JSON by Benoit Blanchon ver 6.12.0.
When compiling an example, following errors are showing:
"Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Higher Bandwidth, Disabled, None, Only Sketch, 115200”
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:8:11: error: DynamicJsonBuffer is a class from ArduinoJson 5. Please see arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
DynamicJsonBuffer jsonBuffer;
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:90:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
StaticJsonBuffer<100> jsonBuffer;
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp: In function ‘void commandReceived(char*, byte*, unsigned int)’:
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:8:21: error: ‘jsonBuffer’ was not declared in this scope
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:11:11: error: ‘ArduinoJson::JsonObject’ has no member named ‘success’
if(root.success()) {
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:14:41: error: ‘ArduinoJson6120_000001::enable_if<true, ArduinoJson6120_000001::MemberProxy<const ArduinoJson6120_000001::ObjectRef&, const char*> >::type’ has no member named ‘asObject’
command.payload = &(root["payload"].asObject());
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp: In member function ‘void LosantDevice::sendState(ArduinoJson::JsonObject&)’:
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:90:19: error: expected primary-expression before ‘<’ token
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:90:25: error: ‘jsonBuffer’ was not declared in this scope
C:\xxx\Arduino\libraries\losant-mqtt-arduino-master\src\internal\LosantDevice.cpp:96:8: error: ‘ArduinoJson::JsonObject’ has no member named ‘printTo’
root.printTo(stateStr);
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
