i don’t get errors it blank the command from losant says it sent and the device revived it. the device does see the command and i can see the name of the command but when i try to print it to serial directly it just blank. i have tried the suggestion above before asking. those seem to be not connection issues or they didn’t receive the command. below is my full code
Example that connects an Adafruit Feather Huzzah to the Losant
IoT platform. This example reports state to Losant whenever a button is
pressed. It also listens for the "toggle" command to turn the LED on and off.
Copyright (c) 2016 Losant. All rights reserved.
http://losant.com
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <Losant.h>
#include <Adafruit_NeoPixel.h>
#define PIN 14
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(100, PIN, NEO_RGB + NEO_KHZ400);
// WiFi credentials.
char* WIFI_SSID = "";
char* WIFI_PASS = "";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "";
const char* LOSANT_ACCESS_KEY = "";
const char* LOSANT_ACCESS_SECRET = "";
// Cert taken from
// https://github.com/Losant/losant-mqtt-ruby/blob/master/lib/losant_mqtt/RootCA.crt
static const char digicert[] PROGMEM = R"EOF(
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
)EOF";
BearSSL::WiFiClientSecure wifiClient;
// Set time via NTP, as required for x.509 validation
void setClock() {
configTime(3 * 3600, 0, "pool.ntp.org", "time.nist.gov");
time_t now = time(nullptr);
while (now < 8 * 3600 * 2) {
delay(500);
struct tm timeinfo;
gmtime_r(&now, &timeinfo);
String msgs[6];
bool latch = false;
bool other = false;
void commandChanged() {
// Losant uses a JSON protocol. Construct the simple state object.
// { "Power_State" : true Or false }
StaticJsonDocument<200> doc;
JsonObject root = doc.to<JsonObject>();
// Send the state to Losant.
root["pattern"] = msgs[1];
root["run_time"] = msgs[3];
root["color_1"] = msgs[4];
root["color_2"] = msgs[5];
device.sendState(root);
void powerStateChange(bool state) {
Serial.println("State Change!");
if (state == true) {
root["Power_State"] = true;
} else {
root["Power_State"] = false;
latch = true;
if (strcmp(command->name, "ledCommand") == 0)
Serial.println("");
msgs[1] = payload["pattern"].as<String>();
msgs[2] = payload["cycles"].as<String>();
msgs[3] = payload["runTime"].as<String>();
msgs[4] = payload["color1"].as<String>();
msgs[5] = payload["color2"].as<String>();
//commandChanged();
void connect() {
// Connect to Wifi.
Serial.println();
Serial.println();
Serial.println(WIFI_SSID);
delay(500);
Serial.print(".");
// Validating the SSL for for a secure connection you must
// set trust anchor, as well as set the time.
BearSSL::X509List cert(digicert);
wifiClient.setTrustAnchors(&cert);
setClock();
Serial.println("");
// Connect to Losant.
Serial.println();
// For an unsecure connection.
//device.connect(wifiClient, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET);
while (!device.connected()) {
delay(500);
//Serial.println(device.mqttClient.state()); // HERE
Serial.print(".");
Serial.println("Connected!");
void colorWipe(uint32_t c, uint8_t wait) {
for (uint16_t i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
device.loop();
delay(wait);
Serial.println(msgs[1]);
void colorsWipe(int wipeTime) {
latch = false;
colorWipe(strip.Color(255, 0, 0), wipeTime); // Red
colorWipe(strip.Color(255, 128, 0), wipeTime);
colorWipe(strip.Color(255, 255, 0), wipeTime);
colorWipe(strip.Color(128, 255, 0), wipeTime);
colorWipe(strip.Color(0, 255, 0), wipeTime); // Green
colorWipe(strip.Color(0, 255, 128), wipeTime);
colorWipe(strip.Color(0, 255, 255), wipeTime);
colorWipe(strip.Color(0, 128, 255), wipeTime);
colorWipe(strip.Color(0, 0, 255), wipeTime); // Blue
colorWipe(strip.Color(128, 0, 255), wipeTime);
colorWipe(strip.Color(255, 0, 255), wipeTime);
colorWipe(strip.Color(255, 0, 128), wipeTime);
// this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
latch = false;
uint16_t i, j;
for (j = 0; j < 256; j++) { // 15 cycles of all colors on wheel
for (i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
device.loop();
delay(wait);
Serial.println(msgs[1] + "t");
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if (WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if (WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
void solidColor(String color) {
latch = false;
if (color == "white") {
colorWipe(strip.Color(255, 255, 255), 50);
} else if (color == "blue") {
colorWipe(strip.Color(0, 0, 255), 50);
} else if (color == "red") {
colorWipe(strip.Color(255, 0, 0), 50);
} else if (color == "green") {
colorWipe(strip.Color(0, 255, 0), 50);
} else if (color == "magenta") {
colorWipe(strip.Color(255, 0, 255), 50);
} else if (color == "yellow") {
colorWipe(strip.Color(255, 255, 0), 50);
} else if (color == "cyan") {
colorWipe(strip.Color(0, 255, 255), 50);
} else if (color == "orange") {
colorWipe(strip.Color(255, 165, 0), 50);
} else if (color == "purple") {
colorWipe(strip.Color(128, 0, 128), 50);
} else if (color == "blueviolet") {
colorWipe(strip.Color(138, 43, 226), 50);
} else if (color == "olivedrab") {
colorWipe(strip.Color(107, 142, 35), 50);
} else if (color == "olive") {
colorWipe(strip.Color(128, 128, 0), 50);
} else if (color == "teal") {
colorWipe(strip.Color(0, 128, 128), 50);
strip.show();
uint32_t colorPicker(String color) {
uint32_t colorPicked;
colorPicked = strip.Color(255, 255, 255);
colorPicked = strip.Color(0, 0, 255);
colorPicked = strip.Color(255, 0, 0);
colorPicked = strip.Color(0, 255, 0);
colorPicked = strip.Color(255, 0, 255);
colorPicked = strip.Color(255, 255, 0);
colorPicked = strip.Color(0, 255, 255);
colorPicked = strip.Color(255, 165, 0);
colorPicked = strip.Color(128, 0, 128);
colorPicked = strip.Color(138, 43, 226);
colorPicked = strip.Color(107, 142, 35);
colorPicked = strip.Color(128, 128, 0);
colorPicked = strip.Color(0, 128, 128);
return (colorPicked);
void colorChase(String background, String forground, int runTime) {
latch = false;
uint32_t forgroundColor;
uint32_t backgroundColor;
int li = 0;
int gi = 0;
forgroundColor = colorPicker(forground);
backgroundColor = colorPicker(background);
Serial.println(forground + forgroundColor);
Serial.println(background + backgroundColor);
for (int i = 0; i < strip.numPixels(); i++) {
li = i - 1;
gi = i + 1;
strip.fill(backgroundColor);
strip.show();
if (li >= 0) {
strip.setPixelColor(li, forgroundColor);
if (gi <= strip.numPixels()) {
strip.setPixelColor(gi, forgroundColor);
strip.setPixelColor(i, forgroundColor);
strip.show();
device.loop();
delay(runTime);
void colorBlink( String background, String forground, int runTime) {
latch = false;
if (other) {
i++;
strip.setPixelColor(i, backgroundColor);
other = false;
} else {
i++;
other = true;
strip.show();
device.loop();
delay(runTime);
void setup() {
Serial.begin(115200);
while (!Serial) { }
// Register the command handler to be called when a command is received
// from the Losant platform.
connect();
strip.begin();
strip.setBrightness(30); //adjust brightness here
strip.show(); // Initialize all pixels to 'off'
powerStateChange(false);
void loop() {
if (msgs[1] == "off") {
Serial.print("off");
strip.clear();
strip.show();
msgs[1] = "off1";
} else if (msgs[1] == "rainbow") {
Serial.print("rainbow");
if (latch) {
powerStateChange(true);
rainbowCycle(msgs[3].toInt());
} else if (msgs[1] == "solid") {
Serial.print("solid");
if (latch) {
solidColor(msgs[4]);
} else if (msgs[1] == "color chase") {
Serial.print("color chase");
if (latch) {
colorChase(msgs[4], msgs[5], msgs[3].toInt());
} else if (msgs[1] == "two color blink") {
Serial.print("two color blink");
if (latch) {
colorBlink(msgs[4], msgs[5], msgs[3].toInt());
} else if (msgs[1] == "colors wipe") {
Serial.print("color wipe");
if (latch) {
colorsWipe(msgs[3].toInt());
bool toReconnect = false;
toReconnect = true;
if (!device.connected()) {
toReconnect = true;
if (toReconnect) {
connect();
device.loop();
delay(100);
