Can't compile Arduino code when using a payload
Hey,
I’m attempting to send a device command to my Arduino (the one from the kit) and I want to include a payload. When I attempt to build it, it errs out.
The error I’m seeing is:
In function 'void handleCommand(LosantCommand*)':
rgbled:26: error: invalid initialization of reference of type 'ArduinoJson::JsonObject&' from expression of type 'ArduinoJson::JsonObject*'
   JsonObject& payload = command->payload;
The revelant section of the code is:
     Serial.println(command->time);
The code is copied from the Losant Github docs.
I’m not super familiar with C, but I guessed it was related to pointer vs object, so I changed the offending line to:
 JsonObject* payload = command->payload;
It compiles but I can’t get any of the payload values!
Any help would be appreciated!
OK, I think I figured it out via trial-and-error:
I’m not sure as to why it works, however.
Looks like your code change is correct. The underlying library is returning a pointer. Not sure why it’s not just returning the reference. I’ll update the docs. Thanks!
