I have set up a workflow to export data to MongoDB, which works great. I need to perform the same task to push data to a site-hosted SQL instance. I have whitelisted a range of IP addresses from Google User Content, but we still periodically see errors returned as the IP address changes and so the query is blocked by the firewall. I also tried looking at what the fully qualified domain name should be but can’t get this to work either.
Is there any specific method I should be following to allow this access from Losant to the database?
@David_Alderson I’ll PM you instructions on how to retrieve our IP addresses.
Hi Dylan, we are securing our external database based on incoming IP-addresses of Losant. Can you please send me instructions how to identifiy the IPv4 addresses of your platform? Thanks.
Manfred van der Voort
You can retrieve Losant’s outbound request IP addresses by performing a DNS lookup against the domain outbound.losant.com - for example, by running the following command on a *nix-based system …
nslookup outbound.losant.com
These IP addresses are subject to change - however, it is rare that they actually do. We recommend building your solutions in a way that they are resilient to unexpected changes to these IP addresses.
Thanks for fast reply. For firewalls we still rely on hard coded IP-addresses.
