Input Controls Range Slider device tag value
In the input controls widget, when using the Range Slider, it doesn’t seem to accept device tags as a static value (though this would work for a text input).
I see what you mean. I’ll file a ticket and try to get that fixed for our April release. Thanks for the bug report.
We’re going to get this fixed but I did discover something you can do in the meantime. Change your template to:
{{ctx.deviceId-0.tags.fanSpeed1.[0]}}
This is because the value of ctx.deviceId-0.tags.fanSpeed1 is actually an array with one item in it. In such cases we typically render this as a string but there is a case where that is not happening in this block. By adding the .[0] to the end, you are explicitly referencing that array value instead of letting Handlebars resolve it to a string first.
Let me know if you have any questions and apologies for the bug.
That’s great, thanks for the quick response :slight_smile:
Our latest platform release just went out; you can continue to use the alternative method to reference a device tag value that I provided but the method you tried originally should also work, too.
Many thanks Dylan, looking forward to trying it out :slight_smile:
