How to insert DeepSleep into NodeMCU DHT22 Temp/Hum Monitoring Code on Losant
Dear Team,
Please I need help in where to insert “DeepSleep” in my code monitoring temperature and humidity. Below is my code, please anyone with idea on where is proper to insert “DeepSleep” should please guide me:
 * Example for sending temperature and humidity
 * to the cloud using the DHT22 and ESP8266
 * https://www.losant.com
#include "DHT.h"
#include <ESP8266WiFi.h>
#include <Losant.h>
#define DHTPIN 4     // what digital pin the DHT22 is conected to
#define DHTTYPE DHT22   // There are multiple kinds of DHT sensors
DHT dht(DHTPIN, DHTTYPE);
// WiFi credentials.
const char* WIFI_SSID = "xxxxxxxxxxxx";
const char* WIFI_PASS = "@xxxxxxxxxx";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "5c064ad5a1dcxxxxxxxxxxxx";
const char* LOSANT_ACCESS_KEY = "34197995-7e48-4d82-8257-xxxxxxxxxxxx";
const char* LOSANT_ACCESS_SECRET = "d2255fee252267456b795e8800620b92d2fd4bd7b9529fefb296xxxxxxxxxxxx";
WiFiClientSecure wifiClient;
void connect() {
  // Connect to Wifi.
  Serial.println();
  Serial.println();
  Serial.println(WIFI_SSID);
  WiFi.persistent(false);
  WiFi.mode(WIFI_OFF);
  WiFi.mode(WIFI_STA);
  unsigned long wifiConnectStart = millis();
    // Check to see if
      Serial.println();
      Serial.print("SSID: ");
      Serial.print("Password: ");
      Serial.println(WIFI_PASS);
      Serial.println();
    delay(500);
    Serial.println("...");
    // Only try for 5 seconds.
    if(millis() - wifiConnectStart > 5000) {
      Serial.println("Failed to connect to WiFi");
      Serial.println("Please attempt to send updated configuration parameters.");
      return;
  Serial.println();
  Serial.println();
  HTTPClient http;
   *     "deviceId": "575ecf887ae143cd83dc4aa2",
   *     "key": "this_would_be_the_key",
   *     "secret": "this_would_be_the_secret"
  String buffer;
  root.printTo(buffer);
  if(httpCode > 0) {
      if(httpCode == HTTP_CODE_OK) {
      } else {
        if(httpCode == 400) {
        } else if(httpCode == 401) {
        } else {
    } else {
  http.end();
  // Connect to Losant.
  Serial.println();
  while(!device.connected()) {
    delay(500);
    Serial.print(".");
  Serial.println("Connected!");
  Serial.println();
void setup() {
  Serial.begin(9600);
  Serial.setTimeout(2000);
  while(!Serial) { }
  Serial.println("Running DHT!");
  connect();
  root["humidity"] = humidity;
  root["tempC"] = tempC;
  root["tempF"] = tempF;
  device.sendState(root);
  Serial.println("Reported!");
int timeSinceLastRead = 0;
void loop() {
   bool toReconnect = false;
    toReconnect = true;
  if (!device.connected()) {
    toReconnect = true;
  if (toReconnect) {
    connect();
  device.loop();
  // Report every 2 seconds.
  if(timeSinceLastRead > 2000) {
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    // Read temperature as Fahrenheit (isFahrenheit = true)
    float f = dht.readTemperature(true);
    // Check if any reads failed and exit early (to try again).
    if (isnan(h) || isnan(t) || isnan(f)) {
      return;
    // Compute heat index in Fahrenheit (the default)
    float hif = dht.computeHeatIndex(f, h);
    // Compute heat index in Celsius (isFahreheit = false)
    float hic = dht.computeHeatIndex(t, h, false);
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print(t);
    Serial.print(" *C ");
    Serial.print(f);
    Serial.print(" *F\t");
    Serial.print("Heat index: ");
    Serial.print(hic);
    Serial.print(hif);
    Serial.println(" *F");
    report(h, t, f, hic, hif);
  delay(100);
  timeSinceLastRead += 100;
Hi @Johnson_Isaac,
Typically, you want your device to wake up, read the sensor, send a message to Losant, then sleep for a specified period.
If you look at the example from the blog you were following:
The deep sleep happens last in the loop function. Essentially, after we done all the steps I mentioned above. You’d likely want yours to be there too.
