File Read Node missing?
Hi folks,
File Read Node is missing from the Node list:
I don’t see it any where on the left menu:
Cheers.
The File: Read Node is only available in Edge Workflows, since it’s used to read files from the gateway’s local file system. If you’d like to access a file from Application Files, I’d recommend the HTTP Node to download it to the payload using it’s URL.
I see makes sense now. Yes I ended up using the HTTP GET via the node and read the file content.
Thanks.
