Hi!
I have a device connected to losant platform and, in general, i can easily deal with its data, since the documentation is very clear about it.
However, there is something i still have trouble doing: exporting the data to an URL (an API returning my attribute values, for example).
I tried using the POST method on the HTTP Node, but when I access the URL, it only returns {“success”:true}.
Basically what i’m trying to do is the opposite of the Weather Station “grabber” workflow: instead of grabbing the attributes from an API and putting it in the platform, I want to grab the attributes from my device and put it on an API. What’s the easiest way to do it?
Hi @Cesar_Guedes, and welcome to the Losant Forums.
It is absolutely possible to send data from Losant to a third party API, but the best way to do so depends on a number of factors:
- Do you want to send the data in real time as it’s being reported to Losant, in small batches on a regular basis, or in large batches infrequently?
- What is the other service in question? Do they only expose an HTTP API or are there other methods of ingesting data into it?
- Out of curiosity, what are you doing with the data in the third-party service? I ask this because I wonder if there is a hole in our product offering that we could fill.
Please let me know, and again, welcome to Losant!
I’d set up a workflow that starts with a Timer Trigger configured to fire on your interval (every 15 minutes).
From there, you can retrieve device data a number of different ways …
Data: Time Series Node: For returning a time range of data from a single attribute across one or many devices
Data: Gauge Query Node: For returning a single value from a single attribute aggregated across one or many devices
Device: Get Node: With the “Composite State” option, this will return one or more devices along with the last reported state values for your selection of attributes
Losant API Node, Data: Time Series Query action: For returning a time range of data across one or more devices and for one or more attributes
- Losant API Node, Data: Last Value Query action
From there, you may need one or more nodes to shape the retrieved data into a format your third-party API expects.
Finally, you can submit the data to your API using a properly configured HTTP Node. What this looks like depends on the API you are interacting with.
Well… that was easy. Thank you very much, Dylan.
