Error Message on importing a workflow. What is the proper extension to use? Seems like .flow and .txt doesnt work.
What is the error message you are getting? Workflow import can fail for a number of reasons … The most typical one, assuming you are trying to import a file that was a workflow export file, is trying to import an edge workflow as an application workflow or vice-versa.
The extension should be .flow.
Could it be that i need IDs and identifiers within it?
Sorry, I’m trying to be helpful but there is still a lot of missing information here. What is “it” when you say “within it”? And what is the actual error message you are receiving here? The more information you can provide, the better. You can also PM me the file you are trying to import.
Hi Dylan. Thank you for the reply. I will send you a PM later this week.
