Hi there,
I’m successfully using the EEA on a few devices and I have deployed many versions of my embedded workflow until this happened (Device Deployment Logs):
I don’t think the problem comes from the embedded workflow as I only did minor changes and tried to restore previous versions without success.
Could this be a problem on the device or on the deployment process?
Note that the device works fine with the previous embedded workflow.
Cheers
Jules
Hey @Jules_Huguenin,
Our error tracking did catch your error and our engineers are investigating. We’ll keep you updated as we learn more and hopefully have a resolution for you as soon as possible.
I can replicate the problem with two scenarios:
1 - Embedded workflow, I had a cascade of conditional nodes (4X, a switch node would have been great but not available with the embedded workflows), and once I removed them it worked.
I can’t see what was wrong with those nodes though.
2 - When I try to deploy more than one workflow
Thanks for the feedback @Jules_Huguenin. Can you attach a copy of the workflow you are running into problems with so we can verify the fix we have on our staging environment will solve your issue?
We also created a feature request for the Switch Node in embedded workflows based on your feedback.
