Dashboard Time-Series Graph resolution synchronization
I have two Time-Series graphs on a dashboard and I would like to link resolution together. For example, then I change one of their resolutions from 4 days, 5mins resolution to 1 day, 1min resolution, i would like both charts to have same resolution. Is this possible?
Yes, if you use the global duration and resolution feature. Configure both blocks to use the global values for each and, when you change the duration and resolution in the dashboard’s menu bar, it will update both graphs.
I use the global values. My question was more to do with “When I change one can the other inherit the one I changed values?”
Outside of the global duration and resolution, we do not have a way of applying changes from one block to a different block, sorry.
