Cell template - Handlebar condition not working
I can’t wrap my head around this especially since I made it work for the map…
As you can see if I simply display the data, it is data.alert_12hr is a boolean.
Now, I want to add images red/green icon and I bump into an issue. For some reason it doesn’t work:
What am I missing here??
You’re really close with this. Once you’ve defined your “Source” (as alert_12hr), you then reference that as value in the “Cell Template”. You can read more about configuring a Device State Table block, but the relevant bit is:
In the Cell template, the name variable is available, as well as a value variable, which is the actual value backing that cell.
So for your situation, your “Cell Template” might look like this:
{{#if value}}
  ![](https://dummyimage.com/24/00aa00/00aa00)
{{else}}
  ![](https://dummyimage.com/24/aa0000/aa0000)
{{/if}}
Those dummy images are for green and red blocks respectively.
