I have a dashboard Indicator block configured for Live Stream updates, with with the following expression: {{value-0}} === ‘open’ which is an evaluation of a string attribute on a device, for which a custom decoding workflow will set to either “open” or “closed” on the updated payload path at “data.decoded.door” beforehand, which is then used to set the actual device string attribute named “DoorState” in a “Device: State” workflow node. I can verify this attribute state is occurring as expected from dumping it into a DataTable also. However, I cannot get the Indicator block to properly evaluate the {{value-0}} === ‘open’ & {{value-0}} === ‘closed’ string expressions and select the different colour indicators as configured. It always triggers the Default state and colour on a live update. As far as I can tell from your Expression evaluation and other documentation, this should work as it should be being treated as a JavaScript string comparison.
I also cannot get the Indicator Block text or label to dynamically update from the Handlebars style Door Status {{data.decoded.door}} definitions either.
Am I missing something here?
