Calling GCP Cloud Function using GCP Function and HTTP Trigger
My 2nd Gen GCP Cloud Function has a run.app url, not a cloudfunctions.net url…
I am unable to configure the node since it insists on a cloudfunctions.net url.
Is there a known workaround for this?
I have tried to build the equivalent url for the function based on the pattern of the cloudfunctions.net url (using region, project-id and function name) but it finds no endpoint.
Best,
Tim.
I just tested this and verified the issue you are running into. We’re working on a fix and should hopefully have it out next week. Thanks for bringing this to our attention.
In the meantime, you could use an HTTP Node to invoke the function.
Thanks Dylan.
Appreciate greatly the confirmation and response.
It’s the Token key in JSON format security functionality I was really wanting from the GCP Function Node…
That has been very solid approach for use with BigQuery calls.
I have been able to get the HTTP node to fire using “Authorization : bearer XXXX…” header arguments, using a token copied from a gcloud console… but - as I understand it - that is not good practice and those tokens are temporary.
(I am definitely no expert on authorisation… and it’s been a steep learning curve in GCP with different mechanism in different circumstances etc…).
Best,
Tim.
Thankyou, Dylan… this now works!
