We are using a doc to deploy a docker container which forwards to trigger a webhook. It is hosted on an AWS server with the UDP port exposed within my org. The thing is I don’t know much about the payload structure for the request and response but one request payload that always works via Packet Sender is:
"type":"Buffer",
"data":[131,5,70,116,3,48,137,1,1,1,2,0,1,90,179,197,97,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,44,0,0,0,0,0,0,31,8,7,2,14,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
it responds with: \83\05Ft\030\89\01\01\02\01\01\02\00\00\00\00\00
Now I think from looking at the request payload structure, it is a buffer converted to json and sent to trigger the webhook. However, I can’t seem to comprehend the response payload format ie., ASCII, Octal, Binary, Buffer, etc.
Furthermore, here is an excerpt from the docker logs:
FORWARDING port 9000 to https://triggers.losant.com/webhooks/l0f8O1fJ1FkxXrdlAkWKTOGIPxBjiK4E4pbJRqPA
9000 INBOUND (49.36.129.204:53589) 7b2274797065223a22427566666572222c2264617461223a5b3133312c352c37302c3131362c332c34382c3133372c312c312c312c322c302c312c39302c3137392c3139372c39372c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c34342c302c302c302c302c302c302c33312c382c372c322c31342c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c302c305d7d
9000 RESP (49.36.129.204:53589) 200
9000 OUTBOUND (49.36.129.204:53589) 830546740330890101020101020000000000
Now, it is self-explanatory what’s happening here however I don’t really understand what the initial buffer JSON has become now and what kind of data the webhook responds with.
Now, I have checked the docs but the payload structure described there is VERY different from what is going on here and this thing is a bit urgent to fix as subsequent payloads are being rejected even with authentication present within the docker config.
It would a big help for me.
Thanks.
Sambhav.
