Hi there,
this is strange, why the CSV function block converts the time string into a linux epoch format?
I don’t see any option in the CSV block that can enable/disable this behavior.
I just want simply to keep the date time as a string.
Cheers.
The data returned by the Data: Time Series Node has the time value in EJSON $date format - which, when encoded into a CSV string as you’ve discovered, falls back to an Epoch millisecond timestamp.
An easy working would be to drop a Function Node between your Data: Time Series Node and the CSV: Encode Node with the following content:
payload.working.data = payload.working.data.map((pt) => {
return {
...pt,
time: new Date(pt.time).toString()
Depending on what string format you want that time value to be in, you could swap that toString() out for one of the other built-in date string methods, or construct your own using the other methods exposed on the object.
